Defining Configurations
The Configuration portal is used to display and maintain configurations.
Refer to Understanding Configuration Types for more information.
You can access the portal from Admin, select C, and then select Configuration. You are brought to a query portal with options for searching for a specific configuration. Once the configuration has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- Configuration: This zone provides information about the configuration, such as asset and specification details.
 - Attachments: This zone displays attachments related to the specific record.
