Defining Organization Types
The Organization Type portal is used to display and maintain organization types.
Refer to Understanding Organizations for more information.
You can access the portal from Admin, select O, and then select Organization Type.
- Organization Type List: This zone lists all organization type records. Broadcast a record to display the details of the selected record.
- Organization Type: This zone displays information about the selected organization type.
