Defining Organizations
The Organization portal is used to display and maintain organizations.
You can access the portal from Admin, select O, and then select Organization. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Organization: This zone displays information about the organization.
  • Child Locations/Organizations: This zone lists the child locations or organizations associated with the current record.
The following zones may appear as part of the portal's Tree View tab page:
  • Organization Hierarchy: This zone displays a hierarchy view for the organization.
