ESRI ArcGIS Server
The Legacy GIS Integration and Map Viewer uses ESRI ArcGIS server to allow users to view asset layers on a map, and to create and view work requests and work orders on the map.
Refer to the Configuring Legacy GIS Integration section of the Oracle Utilities Work and Asset Management Administrative Guide for configuration information after installing.
For ESRI integration functionality, you must purchase ESRI ArcGIS Server software along with Portal for ArcGIS or ArcGIS Online cloud subscription from ESRI.
Perform the following for initial installation and importing the GIS metadata:
  • Installing and Configuring the ESRI ArcGIS Desktop
  • Configuring the Enterprise Geodatabase
  • Importing Data to Geodatabase
  • Publishing Data as Services in the AcrGIS Server
  • Creating web maps using AcrcGIS Online
  • Installing the ArcGIS Web Adaptor
  • Installing and Configuring the ArcGIS Portal
  • Creating web maps using the ArcGIS Portal
  • Configuring Inbound Sync (GIS)
  • Changes to ENVIRON.INI
Notes on SSL:
  • Oracle Utilities Work and Asset Management is set up with SSL (https) enabled as default.
  • ESRI ArcGIS is set up with SSL (https) enabled as default.
