Survey - Questions and Answers
The Survey - Questions and Answers subject area contains data elements related to the surveys available in the Oracle Utilities Opower program, including the Home Energy Analysis (HEA) survey, Savings Hub survey, and Business Profile.
| Data Element | Description |
Answer |
The exact response to the question presented in the survey. The response will vary depending on the type of question. Some questions call for a numeric response, in which case an integer is collected. For example, if the survey presents a question asking users to enter their age, then users will enter a numeric value. Other questions do not require a numeric response, but instead call for a response to a check box, radio button, or drop-down menu. Type: Attribute |
Answer Bucket |
The bucket associated with the response to the given question in the survey. Answer buckets are used to simplify aggregations for numeric answers, such as questions about a customer’s age or the size of the home. For example, for customers who enter a numeric value for their age, the Answer Bucket might group responses into buckets such as 25-35 y.o. and 36-45 y.o. For answers that are non-numeric in nature, the Answer Bucket value typically matches the Answer value. For example, if the survey question is “Do you own your home?“ and the customer answers “Yes”, then the Answer will be “Yes” and the Answer Bucket will also be “Yes”. Type: Attribute |
Is Latest Answer |
A Boolean flag to indicate whether an answer value for a specific survey question is the latest one or not. This is helpful, for example, in the event that an end user answers the same question in a survey at different points in time. Multiple answer values will be recorded, but only one answer value will be the latest. The 'Is Latest Answer' attribute indicates "No" for historical answers and "Yes" for the latest answer. Note: You can pair this data element with a Date dimension such as Date Calendar Date to determine when the latest answer value was made. Type: Attribute |
Question |
The abbreviated form of the survey question. Note: Custom survey questions are included as well, but are not defined in the list of default questions below. Contact your Delivery Team if you need to know the text for any custom survey questions. Questions related to the Business Profile:
Questions related to the Savings Hub survey :
Questions related to the Home Energy Analysis (HEA) Survey:
Type: Attribute |
Response Count |
The total number of responses to questions in the survey. Type: Attribute |
Survey Type |
The type of survey that was taken. The available values include:
Type: Attribute |
Unique Customers Count |
The number of unique customers for whom there are survey results. Type: Measure |
