Survey - Starts and Completions
The Survey - Starts and Completions subject area contains data elements about customer interactions with different surveys available in the Oracle Utilities Opower program, including the Home Energy Analysis (HEA) survey, Savings Hub survey, and Business Profile. For example, you can find engagement metrics such as how many customers started and completed the survey, and how they accessed the survey. With this information, you can gain insight into the performance of the survey in different authentication scenarios.
| Data Element | Description |
                               Auth Type  |
                               A flag to indicate the customer's method of authentication when taking the survey. The available values include:
 Type: Attribute  |
                               Completed Count  |
                               A count of the number of times the survey was completed. Type: Measure  |
                               Completion Rate  |
                               The rate of customers who started and completed the survey. This number is expressed as a percentage and is calculated by simple division: Completed Count / Started Count. Type: Measure  |
                               Conversions  |
                               The number of customers who started the survey flow as anonymous users, and then signed into their account before completing the survey. This is applicable to situations where anonymous users are given the option to complete the survey anonymously, as well as the option to sign in before completing it. Type: Measure  |
                               Event Count  |
                               A sum of the number of customers who started and completed the survey. This number is calculated by simple addition: Started Count + Completed Count. Type: Measure  |
                               Event Type  |
                               A flag to indicate whether the survey was started or completed. Type: Attribute  |
                               Event Timestamp  |
                               A timestamp indicating when the survey was started or completed. Type: Attribute  |
                               Is Csr Event  |
                               A flag to indicate if a Customer Service Representative (CSR) signed in to a customer's account and started or completed the survey on the customer's behalf. For example, this scenario may occur if a customer calls in to their utility to ask for help with general troubleshooting or with improving their energy efficiency tips. Type: Attribute  |
                               Questionnaire Version  |
                               The version of the survey being used. Whenever a change is made to the survey, such as updating a question or adding or removing a question, a new version of the survey is released. The highest Questionnaire Version number refers to the latest version of the survey. With this data, you can track the number of survey starts or completions on a version-by-version basis, or investigate how the latest version of the survey is performing. Type: Attribute  |
                               Started Count  |
                               The number of customers who have started but not finished the survey. Type: Measure  |
                               Survey Type  |
                               The type of survey that was taken. The available values include:
 Type: Attribute  |
                               Unique Customers Count  |
                               A count of unique customers who started or completed the survey. Type: Measure  |
