Customer Classification Definition File
The customer classification definition file describes the segments (classifications) into which customers can be placed. The following table defines the elements that should be provided in the columns of the file.
| Column | Definition |
| classifier |
The main classification name.
Type: VARCHAR Can Be Empty?: No. |
| classifier_description |
Description of the classifier and its purpose for the utility. Type: VARCHAR Can Be Empty?: No. |
| allowed_value |
Possible value for the classifier.
| allowed_value_description |
Description of the allowed value and its purpose for the utility. Type: VARCHAR Can Be Empty?: No. |
| inactive_date |
The date and time at which the
Type: DATETIME (YYYYMMDD HHmm). See Date and Time Handling for details. Can Be Empty?: Yes. |
Additional Notes
To add a new classifier, simply add a new row containing the classifier and
allowed_value pair in the file. To de-activate an existing classifier,
assign an inactive_date to the classifier-allowed value pair. If an inactive
date is assigned to a classifier-allowed value pair, then any new assignments of customers to
that classifier-allowed value that fall after the inactive date will be rejected.
Consult with your Delivery Team to make ensure that the products exhibit the correct behavior for each classifier.Example Customer Classification Definition File
The table below is an example of the Customer Classification Definition File containing different classifiers. These are meant as examples only. Utilities may choose to use these classifier-allowed value pairs or others of their choosing.
| classifier | classifier_description | allowed_value | allowed_value_description | inactive_date |
| low_income | Indicates whether the customer is low-income | True | Tags a low-income customer to receive tips relevant to low-income customers | |
| language | The preferred language of the customer | English | Tags a customer to receive communications in English | |
| language | The preferred language of the customer | French | Tags a customer to receive communications in French | |
| DoNotSolicit | Customers in the "do not solicit" list | True | Exclude these customers from future expansions |
