Customer Classification File
If the Oracle Utilities Opower system encounters any classifiers that have not been already defined in the Customer Classifier Definition file, the corresponding rows in the Customer Classification file will be rejected.| Column | Definition |
customer_id
Unique identifier for the customer. This customer ID should be the same customer ID that is sent in the billed usage files, as described in Customer Fields. Type: VARCHAR Can Be Empty?: No. |
premise_id
Identifier for the premise with which the customer is currently associated. This premise ID should be the same premise ID that is sent in the billed usage data files, as described in Customer Fields. Type: VARCHAR Can Be Empty?: No. |
| classifier |
Key identifying the classifier. The classifier should be the same as one of the classifiers already listed in the corresponding definition file. Type: VARCHAR Can Be Empty?: No. |
| value |
Value for the classification. The value should be the same as one of the allowed values already listed in the corresponding definition file. Type: VARCHAR Can Be Empty?: No. |
| start_date |
The date and time at which the customer is classified according to the classifier/value. This is useful for classifers that are time-sensitive. For example, this could be used if a customer is part of a low-income group for a certain period and then is removed from the group. If left blank, the start date is assumed to be the date of file import. Type: DATETIME (YYYYMMDD HHmm). See Date and Time Handling for details. Can Be Empty?: Yes. |
| end_date |
The date and time at which the customer is no longer classified according to the classifier/value. If left blank, the classification value is assumed to be true indefinitely. If the value for a customer’s classification is changed, and the end date is not explicitly sent by the utility, the end date will be set to the date prior to the start date of the new classification. Type: DATETIME (YYYYMMDD HHmm). See Date and Time Handling for details. Can Be Empty?: Yes. |
Example Customer Classification File
The table below is an example of customer classification data. It is intended as an example only.
| customer_id | premise_id | classifier | value | start_date | end_date |
| 779222413 | 603400 | low_income | True | 20130101 1200 | 20180101 1200 |
| 822022136 | 143344 | low_income | True | 20130101 1200 | |
| 530432863 | 261411 | low_income | True | ||
| 572410557 | 400657 | low_income | True | ||
| 579494002 | 259691 | language | French | 20170601 1200 | |
| 559409440 | 572129 | language | French | ||
| 799909879 | 573400 | language | English |
