Entity Attribute Data File Specifications
There are two separate files that you must send to Oracle Utilities: the Entity Attributes Definition file and Entity Attributes Data file. This section describes the distinct data elements that these data files must contain.
The Entity Attributes Definition file must be sent prior to the Entity Attributes Data file. This is because the attributes defined in the definition file are used to validate the records in the data file.
