Entity Attribute Definition File
The Entity Attributes Definition file describes the attributes with their allowed values. The following table defines the elements that should be provided in the columns of the file.
Field Description
entity_type
The core entity type for the key.
Supported Values:
  • CUSTOMER
    Attribute key associated with CUSTOMER.
  • UTILITY_ACCT
    Attribute key associated with UTILITY_ACCT.
  • SERVICE_POINT
    Attribute key associated with SERVICE_POINT.
  • PERSON
    Attribute key associated with PERSON.
  • ACCOUNT
    Attribute key associated with ACCOUNT.
  • SERVICE_AGREEMENT
    Attribute key associated with SERVICE_AGREEMENT.
  • PREMISE
    Attribute key associated PREMISE.
Type: VARCHAR
Can Be Empty?: No.
Default: Not applicable.
key
The key identifying the attribute. The key is case- insensitive (it can be in lower, upper, or any case). See Example Entity Attributes Definition File for common use cases, such as for preferred languages and low-income customers.
Type: VARCHAR
Can Be Empty?: No.
key_description
A description of the key and its purpose for the utility.
Type: VARCHAR.
Can Be Empty?: Yes.
allowed_value
A possible value for the key.
  • Be consistent with upper and lower case. For example, do not use both True and true. Choose one.
  • Must include only letters, underscores, hyphens, and periods.
  • Special characters are not accepted.
If you are not using enumerated values, then use one of the reserved keywords to define the type of value.
Enumerated values are any fixed sets of known values. For example, for the attribute key LANGUAGE, known enumerated values could be "ENGLISH", "FRENCH".
Type: VARCHAR
Can Be Empty?: No.
allowed_value_description
A description of the allowed value and its purpose for the utility.
Type: VARCHAR.
Can Be Empty?: Yes.
allowed_min_value
The minimum value allowed for this key. This field is applicable only if the allowed_value field above is set to <NUMBER>. This field will be ignored for all other value types. Both, either, or neither of allowed_min_value and allowed_max_value can be populated.
Type: DECIMAL (15,4). See Supported Decimal Formats for details.
Can Be Empty?: Yes.
allowed_max_value
Maximum value allowed for this key. This field is applicable only if the allowed_value field above is set to <NUMBER>. This field will be ignored for all other value types. Both, either, or neither of allowed_min_value and allowed_max_value can be populated.
Can Be Empty?: Yes.
source
Source of the key. For example, this should be UTILITY if the utility is sending the data.
Type: VARCHAR
Can Be Empty?: No.
RESERVED Keywords in Definition File
Keyword Allowed Value Details Examples of Allowed Values Examples of Not Allowed Values
<NUMBER>
Type: DECIMAL(15,4).
See Supported Boolean Formats for more details.
  • 123.89
  • 0.01234
  • -2147483647
  • 2147483647
  • 100000000.00
  • "123Test"
  • "stringValue"
  • "alphaNumeric data"
  • 1.234,56
  • 100000000,00
  • 100,000,000.00
  • 100.000.000,00
  • 100_000_000.00
<DATETIME>
Type: DATETIME.
See Date and Time Handling for more details.
2007-06-05T12:30:00-America/New_York 2016-10-12 09:12:00 -7:00
<BOOLEAN>
Type: BOOLEAN.
  • TRUE
  • T
  • F
  • FALSE
  • 0
  • on
  • off
  • TR
  • ACCEPTED
  • NA
  • N/A
  • NULL
  • NONE
The table below is an example of the Entity Attribute Definition File data containing different keys and descriptions. These are meant as examples only. Utilities may use these allowed value pairs or others of their choosing.
key key_description entity_type allowed_value allowed_value_description allowed_min_value allowed_max_value source
language The preferred language of the customer CUSTOMER English Tags a customer to receive communications in English     UTILITY
language The preferred language of the customer CUSTOMER French Tags a customer to receive communications in French     UTILITY
has_ev Customer has electric vehicle CUSTOMER <BOOLEAN> True/Yes if customer has electric vehicle     UTILITY
event_date Date of start of the event CUSTOMER <DATETIME> Actual event start date. Does not represent event creation date.     UTILITY
performance_dollar Rebate earned during this period of time. CUSTOMER <NUMBER> Rebates should be negative or zero amounts. No positive amounts should be provided. -99999 0 UTILITY
total_dues Total dues CUSTOMER <NUMBER>
  9999.99 UTILITY
tax_charge Tax charged CUSTOMER <NUMBER>
100   UTILITY
household_income Income for current calendar year CUSTOMER <NUMBER>
    UTILITY
