Entity Attributes Data File
The Entity Attributes Data file lists the attributes and their respective values. The table below defines the elements that must be included in the columns of the file.
| Field | Description |
| entity_id |
Entity identifier. The entity ID should be established following the rules and requirements in Account Data Transfer, Billing Data Transfer, or Premise Data Transfer. Type: VARCHAR Can Be Empty?: No. |
| entity_type |
The core entity type for the key. Supported Values:
Type: VARCHAR Can Be Empty?: No. Default: Not applicable. |
| key |
Key identifying the attribute. See Example Entity Attributes Data File for common use cases, such as for solar customers and low-income customers. Type: VARCHAR Can Be Empty?: No. Default: Not applicable. |
| value |
Value for the attribute. See Example Entity Attributes Data File for common use cases. If you are not using enumerated values, then use one of the reserved keywords to define the type of value. See RESERVED Keywords in Definition File for details. Enumerated values are any fixed sets of known values. For example, for the attribute key LANGUAGE, known enumerated values could be ENGLISH, FRENCH. Type: VARCHAR Can Be Empty?: No. |
| start_datetime |
The effective start date and time of the specified attribute value. This field may be left NULL if the value is effective from the beginning of time. The start datetime value is inclusive (for example, from 2019-02-27T00:00:00-America/New_York, and onwards). See Date and Time Handling for more guidance. Type: DATETIME (YYYY-MM-DD<T>hh:mm:ss-<timezone>) Can Be Empty?: Yes. |
| end_datetime |
The date and time on which the specified attribute value is no longer effective. This datetime value is not part of the period covered by the attribute key. This field may be left NULL if the value is effective indefinitely. The end datetime value is exclusive (for example, until 2024-04-13T00:00:00-America/New_York, excluding that instant). See Date and Time Handling for more guidance. Type: DATETIME (YYYY-MM-DD<T>hh:mm:ss-<timezone>) Can Be Empty?: Yes. |
| source |
Source of the key. For example, this should be UTILITY if the utility is sending the data. Type: VARCHAR. Can Be Empty?: No. Default: Not applicable. |
The table below is an example of entity attributes data. It is intended as an example only.
| entity_id | entity_type | key | value | start_datetime | end_datetime | source |
| 779222413 | CUSTOMER | has_ev | True | 2018-06-09T12:30:00-America/New_York | UTILITY | |
| 822022136 | CUSTOMER | has_ev | True | 2019-06-05T12:30:00-America/New_York | UTILITY | |
| 530432863 | CUSTOMER | low_income | True |
2007-06-05T12:30:00-America/New_York | UTILITY |
| 572410557 | CUSTOMER | has_solar | True | 2022-06-05T12:45:00-America/New_York | UTILITY | |
| 579494002 | CUSTOMER | language | French | 2021-11-10T10:30:00-America/New_York | 2022-11-09T10:30:00-America/New_York | UTILITY |
| 662410557 | CUSTOMER | language | English | 2022-12-15T11:45:00-America/New_York | UTILITY | |
| 662410557 | CUSTOMER | performance_ dollars | -10.35 | 2022-12-15T11:45:00-America/New_York | UTILITY | |
| 662410557 | CUSTOMER | performance_value | 0.445 |
UTILITY | |
| 662410557 | CUSTOMER | event_date | 2023-01-15T00:00:00-America/New_York | 2022-03-05T12:30:00-America/New_York | UTILITY |
