Peak Time Rebates File
In order to support rate plans with rebate components, the Rate Engine must receive the calculated rebates for each customer. This peak time rebates file should be transmitted after the event date and after the rebates have been calculated by the utility billing system. The file must follow a specific naming convention. See Rates Data File Name Conventions for more information.
Note: This file is only if applicable if your utility needs to provide peak time rebates data in support of certain products. Your Delivery Team will work with you to determine if it is required in your situation.
Column Name Description
account_id
Account identifier.
Type: VARCHAR
Can Be Empty?: No.
rate_plan_identifier
The rate plan for which the rebate is applicable. This may be a wildcard (*) if the rebate applies to all rate plans for which the Service Agreement (SA) is eligible.
Type: VARCHAR
Can Be Empty?: No.
rate_component
The unique identifier of the type of rate component to which the rebate applies.
Type: VARCHAR
Can Be Empty?: No.
start_date
Effective start date of the specified rebate value.
Type: DATETIME. See Date and Time Handling for details.
Can Be Empty?: Yes.
end_date
Effective end date of the specified rebate value. This should be exclusive. For example, if the rebate is calculated in hourly increments and ends at 11:00, the end_date should be 20120101 1100. The hour from 11:00-12:00 will not be included.
Can Be Empty?: Yes.
performance_value
kWh or Therm value used to calculate the rebate amount for this period. A positive value should be sent for customers who used less than their baseline. A negative value should be sent for customers who used more than their baseline.
Type: DECIMAL (12,6). See Supported Decimal Formats for details.
Can Be Empty?: No.
performance_dollars
Rebate earned during this period of time. Prices should always be provided in dollars, not cents. Rebates should be negative or zero amounts. No positive amounts should be provided.
Can Be Empty?: Yes.
Peak Time Rebates Sample Data
The peak time rebates file specifies pricing information related to the rebates that a customer can receive by participating in a peak day event. The table below provides an example of how the data might look.
account_id rate_plan_identifier rate_component start_date end_date performance_ value performance_ dollars
123 R_PTR PEAK_TIME_REBATE 20120101 1300 20120101 1900 5.354 -10.3507471
456 RL_PTR PEAK_TIME_REBATE 20100609 1200 20100609 1300 1.248 -2.1667152
456 RL_PTR PEAK_TIME_REBATE 20100609 1300 20100609 1400 0.445 -0.7725868
456 RL_PTR PEAK_TIME_REBATE 20100609 1400 20100609 1500 0.139 -0.2413249
