Holidays and Seasons File
Many pricing plans have pricing associated with holidays and seasons. For example, in some TOU plans, all weekends and holidays may be considered “off peak.” Additionally, in many rate plans, prices vary between summer and winter. The purpose of this file is to provide holiday and/or season information to Oracle Utilities. The data must be provided in a single file that follows a specific naming convention. See Rates Data File Name Conventions for more information.
| Column Name | Description |
| rate_plan_identifier |
The unique rate plan for which the event is applicable. This may be a wildcard (*) if the event is applicable to all rate plans. Type: VARCHAR Can Be Empty?: No. |
| rate_component |
The unique identifier of the rate component for which the event is applicable (for example, "CPP"). This may be a wildcard (*) if the event is applicable to all rate components in the specified rate plan. Type: VARCHAR Can Be Empty?: No. |
| season |
The applicable season. This is not applicable for holiday definitions. Only include this if sending season information. Type: ENUM Allowed Values:
Can Be Empty?: Yes. |
| day_type |
The type of day. This is used to define the holiday. This is not applicable for season definitions. Type: ENUM Allowed Values:
| period |
The period being defined. This is not applicable for holiday definitions. Type: ENUM Allowed Values:
| ordinal |
Allows for distinguishing events with same season, day_type, and period. This is not applicable for holiday definitions. Type: INTEGER (1-10) Can Be Empty?: Yes. |
| resolution |
Used in combination with the Type: ENUM Allowed Values:
| duration |
Used in combination with the Type: INTEGER Can Be Empty?: No. |
| start_date |
The start date of the season. This is not applicable for holiday definitions. Type: DATE (MMDD) Can Be Empty?: Yes. |
| start_time |
Start time of the event in military time. The value should be 0000 for holiday definitions. Do not specify a timezone. The local timezone of the utility is assumed. Type: TIME (HHMM) Can Be Empty?: No. |
| event_date |
The date of the holiday. This is not applicable for seasons. Type: DATE (YYYYMMDD) Can Be Empty?: Yes. |
| effective_start_date |
Not applicable for holiday definitions. Type: DATE (YYYYMMDD) Can Be Empty?: Yes. |
| effective_end_date |
Holidays and Seasons Sample Data
The holidays and seasons data file specifies different pricing information related to special holidays or seasons of the year, such as winter and summer. The tables below provide examples of how holidays and seasons data might look.
Holidays Sample Data
| rate_plan_identifer | rate_component | season | day_type | period | ordinal | resolution | duration | start_date | start_time | event_date | effective_start_date | effective_end_date |
| * | * | HOLIDAY | DAY | 1 | 0000 | 20100704 | ||||||
| * | * | HOLIDAY | DAY | 1 | 0000 | 20101225 |
Seasons Sample Data
| rate_plan_identifier | rate_component | season | day_type | period | ordinal | resolution | duration | start_ date | start_time | event_date | effective_start_date | effective_end_date |
| * | * | SUMMER | MONTH | 6 | 0501 | 0000 | 20110501 | |||||
| * | * | WINTER | MONTH | 6 | 1101 | 0000 | 20111101 |
