Rate Period Definitions File
Many pricing plans have periods associated with different prices. For example, in a TOU plan, afternoon hours may be “on peak.” The purpose of the rate period definitions file is to provide rate period configuration information to Oracle Utilities for these types of plans. This file should be provided on a periodic basis at the same frequency at which rate periods change. Note that when defining TOU periods, off-peak periods should not be explicitly defined. On-peak and part-peak periods should be defined, and the system will default any other times that are not covered by on-peak and part-peak as off-peak. The data must be provided in a single file that follows a specific naming convention. See Rates Data File Name Conventions for more information.
This data is only required if you have a time of use (TOU) plan or another pricing plan that requires rate periods. Your Delivery Team will create the file and work with you to gather the necessary inputs.
Column Name Description
rate_plan_identifier
The unique rate plan for which the event is applicable. This may be a wildcard (*) if the event is applicable to all rate plans.
Type: VARCHAR
Can Be Empty?: No.
rate_component
The unique identifier of the rate component for which the event is applicable (for example, ‘TOU’). This may be a wildcard (*) if the event is applicable to all rate components in the specified rate plan.
Type: VARCHAR
Can Be Empty?: No.
season
The season for which the period is being defined.
Type: ENUM
Allowed Values:
  • WINTER
  • SPRING
  • SUMMER
  • FALL
Can Be Empty?: Yes.
day_type
The type of day for which the period is being defined.
Type: ENUM
Allowed Values:
  • WEEKEND
  • WEEKDAY
  • HOLIDAY
Can Be Empty?: Yes.
period
The period being defined.
Type: ENUM
Allowed Values:
  • ON_PEAK
  • PART_PEAK
  • OFF_PEAK
  • CRITICAL_PEAK
  • NON_CRITICAL_PEAK
Can Be Empty?: No.
ordinal
Allows for distinguishing events with same season, day_type, and period.
Type: INTEGER (1-10)
Can Be Empty?: Yes.
resolution
Used in combination with duration to indicate the length of time covered by the event.
Type: ENUM
Allowed Values:
  • QUARTER_HOUR
  • HALF_HOUR
  • HOUR
  • DAY
  • BILLING
  • MONTH
  • YEAR
Can Be Empty?: No.
duration
Used in combination with resolution to indicate the length of time covered by the event.
Type: INTEGER
Can Be Empty?: No.
start_date
Not applicable for rate periods.
Type: DATE (MMDD)
Can Be Empty?: Yes.
start_time
Start time of the event in military time. Do not specify a timezone. The local timezone of the utility is assumed.
Type: TIME (HHMM)
Can Be Empty?: No.
event_date
Type: DATE (YYYYMMDD)
Can Be Empty?: Yes.
effective_start_date
The date on which this event configuration becomes effective.
Can Be Empty?: No.
effective_end_date
Date on which the configuration is no longer effective, if known. This day is not part of the event period.
Can Be Empty?: Yes.
Rate Period Sample Data
The rate period definitions file provides configuration information for pricing plans that have different prices for different periods of time. The table below shows an example of how the rate prices file might look.
rate_plan_identifier rate_component season day_type period ordinal resolution duration start_date start_time event_date effective_start_date effective_end_date
Rate-1 * SUMMER WEEKDAY ON_PEAK 1 HOUR 6 1200 20090101
Rate-1 * SUMMER WEEKDAY PART_PEAK 1 HALF_HOUR 7 0830 20090101
Rate-1 * SUMMER WEEKEND PARK_PEAK 2 HALF_HOUR 7 1800 20090101
Rate-1 * WINTER WEEKDAY PART_PEAK 1 HOUR 13 0800 20090101
* CPP CRITICAL_PEAK HOUR 6 1200 20090101
