Customer Classification Data Verification Checklist
Use the checklist in this section to ensure you have completed all required actions before sending the data files to Oracle Utilities.
File Format Checks
- The filename follows the appropriate pattern. See Customer Classification File Name Conventions for more information.
- The file is tab-delimited and is in .tsv or .txt format.
- The same number of tabs exists in each row.
Header Row Checks
Column headers must match exactly the headers shown below.
Customer Classification Definition File:
classifier classifier_description allowed_value allowed_value_description
inactive_date
Customer Classification File:
customer_id premise_id classifier value start_date end_date
Data Field Checks
- All data fields in the Customer Classification Definition file follow the rules described in this document. See Customer Classification Definition File.
- All data fields in the Customer Classification file follow the rules described in this document. See Customer Classification File.
- Null values are empty strings. (They must be not denoted by /N, NA, null, or some other non-supported notation.)
