Entity Attribute Data Version History
The following table lists updates to the entity attribute data specification by version number and date. The latest version number should be used in the file name that you send to Oracle Utilities. See Entity Attribute File Name Conventions for more information.
| Update | Specification Version Number | Date |
Update
components of DATETIME references in Entity Attribute Definition File and Example Entity
Attributes Data File to use underscores. Update
entity_type column description in Entity Attribute Definition File to include PREMISE as
a supported value.
v1-3-0 | 06/27/2025 |
| Update naming convention in the Entity Attribute File Name Conventions section. | v1-2-0 | 07/31/2024 |
| Initial version. | v1-1-0 | 12/03/2023 |
