Interval Data Version History
The following table lists updates to the interval data specification by version number and date. The latest version number should be used in the file name that you send to Oracle Utilities. See Interval Data File Name Conventions for more information.
| Update | Specification Version Number | Date |
Update the
value of GEN to GENERATED in the
service_quantity_identifier description in Interval Data File Specifications.
v2-0-5 | 08/26/2025 |
| Add information about support for five-minute interval AMI data reads to Interval Data File Specifications and Interval Data File Name Conventions. | v2-0-4 | 03/17/2025 |
Remove
device_label from Interval Data File Specifications since the same data is being supported by Device Fields in the Premise
data transfer specification.
v2-0-3 | 07/31/2024 |
Update the
units field in Interval Data File Specifications to have the same units of measure as the
units_of_measure field in the Measuring Components section
of the Premise data transfer specification.
v2-0-2 | 12/20/2023 |
| Update all instances of "String" to "VARCHAR" in Interval Data File Specifications. | v2-0-1 | 07/20/2023 |
Begin new major version due to significant expansion of the specification. Add the following columns to Interval Data File Specifications to capture more attributes about meters and better support multi-channel interval reads:
Remove the |
v2-0-0 | 07/19/2023 |
| Update Interval Data File Specifications to include a cross-reference to the new File Transfer Limits topic available. | v1-17-0 | 04/17/2023 |
| Update Interval Data File Name Conventions to be clearer about file name length limit and what file name components are required. | v1-16-0 | 04/11/2022 |
| Fix typo in date format in Interval Data File Specifications. | v1-15-0 | 12/06/2021 |
Update the
date and time fields in Interval Data File Specifications to use clearer date and time references. Clarify
that zip files should only contain one file each.
v1-14-0 | 11/23/2021 |
| Update some terms to use more inclusive language. | v1-13-0 | 05/12/2021 |
Update
register_id description to explain how it maps to
another field in the Oracle Utilities premise data file.
v1-12-0 | 10/09/2020 |
Update note in
the units field to clarify the rules regarding units of
measurement for service points with multiple registers. Move information
about the file retention policy to a more prominent place.
v1-11-0 | 05/14/2020 |
Update accepted
value representing water gallons for the units field.
Clarify how to provide data for the time field for
24-hour interval data files. Clarify how to handle daylight saving time
in the Interval Data File Specifications section.
v1-10-0 | 02/11/2020 |
| Clarify file extension requirements and expectations. | v1-9-0 | 11/12/2019 |
Update the list
of supported values for the units field in the Interval Data File Specifications section. Add new register_id
field.
v1-8-0 | 06/14/2019 |
| Edit sections and headings to simplify content. No substantive changes to technical specifications. | v1-7-0 | 01/10/2019 |
| Updated file retention section to reflect regional differences. | v1-6-0 | 05/08/2018 |
| Added statement about valid end-of-line separators. | v1-5-0 | 03/19/2018 |
| Updated description of file transfer process. Added information about correcting file upload errors and Oracle file retention policy. | v1-4-0 | 03/02/2018 |
| Added a statement about the utility's data obligations. | v1-3-0 | 03/30/2017 |
| Added document number and updated branding. | v1-2-0 | 02/14/2017 |
| Added legal notices. Updated document branding. | v1-1-0 | 01/11/2017 |
| Added baseline specification version number to the document. Updated naming conventions to include instructions on how to specify a population token and specification version number in the data file. | v1-0-0 | 09/26/2016 |
| Added note about maximum file size of 4 gigabytes. Updated document formatting. | Not applicable. | 6/3/2016 |
