Sort Key
The following table defines the structure of the sort key that appears on each bill print record. Please note that different components are filled in for each printer key.
Field Name
Format
Source/Value/Description
Bill Print Intercept
A8
This is the user ID, if any, who reviews the bill (as specified on the account record)
Bill ID
A12
Sequence Number
N2
The sequence number of the account / person information associated with this bill routing information.
Copy Number
N2
The number of copies desired by the account / person associated with this bill routing information.
Bill record group
A2
10 Bill
20 Payment
30 Current charge
40 Message
50 Non-Premise
55 Non-Premise end
60 Premise
70 Bill end
Filler
A2
Premise State
A6
Only applicable for Premise based records.
Premise City
A90
Premise Address 1
A64
Premise Id
A10
Premise record group
A2
10 Premise record
20 SA level record
30 Premise end record
SA Print Priority
A2
SA Id
A10
SA Group
A2
For Premise based records:
10 SA
20 Histogram
30 Current charge
40 Adjustment
50 SA end record
For Non-Premise based records:
10 SA
20 Current Charge
30 Adjustment
40 SA end record
Bill Segment End Date
A10
If the record is related to an adjustment, this is the adjustment creation date.
If the record is for histogram detail, this contains the histogram detail number.
Bill Segment Id
A12
If the record is related to an adjustment, this is the adjustment ID.
Bill Segment Group
A2
10 Bill segment
20 Bill segment calculation group
30 Bill segment read detail
40 Bill segment SQ detail
50 Bill segment item detail
55 Bill segment message
60 Bill segment end
Bill Calc Header Sequence
N2
For records related to read detail, SQ detail, item detail or bill message detail, this field contains the related sequence number for that record.
Bill Calc Header Group
A2
10 Bill calculation header
20 Bill calculation line
30 Bill calculation end
Line Seq
N3
Defines order of rows for similar record types
Filler
47
Only applicable for non-premise based records. (This makes up for the premise address related fields that are not applicable above).
