Meter Data Management Table Setup Sequence
This section provides the suggested order for the setup of Meter Data Management administrative data.
| Sequence | Entity | Description |
| 1 | Quantities measured and recorded by the system (CCF, KWH, KW, etc.). | |
| 1 | Used to further distinguish between measured quantities that have identical UOM/TOU combinations. | |
| 1 | Modifiers for a given unit of measure that indicate a period of time during which a quantity has been used (On- Peak, Off-Peak, etc.). | |
| 1 | Centrally stored sets of values for use in validation rules, bill determinants calculations, and other processes. | |
| 1 | Defines jurisdictions or regulatory environments in which a Service Point participates. | |
| 1 | Defines the schedule for manual meter reading of devices at Service Points in that cycle | |
| 1 | Define the dates on which devices are scheduled to be read for a given measurement cycle. | |
| 1 | Defines messages sent to external systems. | |
| 1 | Defines types of schedules that can be referenced by different processes and objects. | |
| 2 | Defines External Systems with which Oracle Utilities Meter Data Management should be able to communicate. | |
| 3 | External entities that serve various roles relative to the application (head-end systems, billing systems, market participants, outage management systems, etc.). | |
| 3 | Defines properties of a class of entities (businesses, persons). | |
| 4 | Defines properties common to a specific type of activity. | |
| 4 | Define properties common to a specific type of communication. | |
| 4 | Defines specific types of tasks performed by external users (self-service meter reads, self-service outage notifications, etc.) | |
| 4 | Defines information common to dynamic options of a specific type. | |
| 4 | Individual companies that makes devices. Manufacturers also reference models. | |
| 4 | Defines properties common to VEE Exceptions of a specific type. | |
| 5 | Collections of VEE Rules that are applied to initial measurement data. | |
| 6 | Standard and custom VEE Rules that perform checking and/or manipulation of initial measurement data. | |
| 7 | Dictates whether a VEE Rule can execute based on a set of defined criteria. | |
| 8 | Defines the most important properties of a measuring component. | |
| 8 | Defines details by which measuring component data can be compared to determine the days that most closely resemble a specific day being evaluated. | |
| 9 | Defines properties of Device Configurations of a given type. | |
| 10 | Defines information about a class of devices. When setting up Device Types, device type codes should match corresponding asset type codes in Operational Device Management (see Operational Device Management Table Setup Sequence). | |
| 11 | Defines specific types of points at which service is delivered. | |
| 11 | Defines types of quantities that can be stored for a service point. | |
| 12 | Used to limit the set of Time Of Uses that are usable in a TOU schedule. | |
| 13 | Schedules used for TOU map data generation. | |
| 14 | Define important properties of TOU maps of a given type. | |
| 15 | Defines properties common to Usage Transaction Exceptions of a specific type. | |
| 15 | Collections of usage calculation rules that are applied to measurement data to calculate bill determinants for usage subscriptions. | |
| 16 | Defines rules that perform calculations on measurement data to generate bill determinants and other values used by external systems. | |
| 17 | Dictates whether a usage calculation rule can execute based on a set of defined criteria. | |
| 18 | Defines collections of properties common to a set of Usage Subscriptions. | |
| 19 | Defines the source of data for dynamic aggregation, such as measurement data from usage subscriptions linked to a service point, badged or unbadged items, or measuring component sets | |
| 19 | Define the most important properties of a measuring component used with dynamic aggregation. | |
| 19 | Measuring Component Set | Define the dimensions and criteria by which dynamic aggregation will be performed. |
| 19 | Define the ordering of a series of related aggregations based on a set of configured measuring component Sets. | |
| 20 | Control various behaviors for external applications, head end systems, and market participants within the system such as which message is sent, how an external value is translated, among others. | |
| 20 | Configuration that applies to series of modules that acts as a central point of configuration rather than embedding repetitive configuration throughout a set of algorithms. | |
| 20 | Information Lifecycle Management (ILM) is designed to address data management issues, with a combination of processes and policies so that the appropriate solution can be applied to each phase of the data's lifecycle. | |
| 20 | Defines the extract parameters, the bucket configurations and configuration snapshots used for extracting data for Oracle Utilities Analytics |
