Understanding Data Export
The application supports the following classes of export methods for a maintenance object:
  • Generalized. This method may be used for maintenance objects that are low to medium in volume and update activity. Most maintenance objects are eligible for this method.
  • Specialized. This method should be used for maintenance objects that are high in volume or very frequently updated.
This section discusses concepts and guidelines related to data export features.
