Billable Charge Template - Line Characteristics
Open Admin > Billing > Billable Charge Template > Search and navigate to the Line Characteristics page to define your billable charge templates line characteristics.
Description of Page
The Line Sequence scroll defines the billable charge template line to which you wish to assign characteristic values.
The characteristics grid supports all standard characteristic types (such as, Adhoc, Predefined, File Location, and Foreign Key) from the Billable Charge Template Line Characteristics table.
To modify billable charge template line characteristics, simply move to a field and change its value. To add characteristics, press + to insert a row and then fill in the information for each field. The following fields display:
Characteristic Type The type of characteristic.
Characteristic Value The value of the characteristic.
