Billable Charge Template - SQ Details
Open and navigate to the SQ Details page to define your billable charge templates service quantities.
Description of Page
To modify a template's service quantity, simply move to a field and change its value. To add a new service quantity to the billable charge template, press the + button to insert a row and fill in the information for each field. The following fields display:
Sequence Specify the sequence number of the SQ.
UOM Select the unit of measure of this SQ. One or more of UOM, TOU, or SQ identifier must be selected.
TOU Select the time of use period.
SQ Identifier Select the SQ identifier.
Service Quantity Specify the number of units of this service quantity.
