Customer Information Zone
The Customer Information Zone is a grid that contains information about the current person and account. Pushing the button adjacent to the information transfers you to an appropriate page. The following table lists the type of information that may appear in this zone and the page to which you will be transferred if you push the adjacent button.
Rows are suppressed if the related data is blank for the person / account.
Label |
What Is Displayed |
Drill Down Transfers You To |
Account ID |
The account's unique identifier (i.e., account ID) is displayed |
An account context menu has been provided (allowing you to drill to a variety of account-oriented pages) |
Main Customer |
The main customer's name. Note, the person's name is formatted by a plug-in algorithm on the installation record. Refer to the base package's name format algorithm (PERS-INFO) for an example. If you prefer different formatting logic, your system administrator should configure the system appropriately |
A person context menu has been provided (allowing you to drill to a variety of person-oriented pages) |
Set Up Date |
The account's setup date |
Account - Main |
CIS Division |
The account's CIS division |
Account - Main |
Customer Class |
The account's customer class |
Account - Main |
Bill Cycle |
The account's bill cycle |
Account - Main |
Current Credit Rating |
The account's current credit rating |
Account - C&C |
Next Credit Review Date |
The next date on which the account's debt will be reviewed by the account debt monitor. Refer to When Is An Account's Debt Monitored for more information. |
Account - C&C |
A separate row is displayed for each characteristic linked to the account. Each row's label is the characteristic type's description. If the characteristic is future dated, the effective date enclosed in parentheses prefixes the description. |
The characteristic's value |
Account - Characteristic |
Auto Pay Source |
The account's auto pay source |
Account - Auto Pay |
A separate row is displayed for each miscellaneous person linked to the account. Each row's label is the person relationship type's description. |
The main name of the miscellaneous person |
Budget Plan |
The account's budget plan |
Account - Budget |
A separate row is displayed for each characteristic linked to the person. Each row's label is the characteristic type's description. |
Person - Characteristic |
A separate row is displayed for each telephone number linked to the person. Each row's label is the phone type's description. |
The telephone number |
Person - Main |
A separate row is displayed for each identifier linked to the person. Each row's label is the ID type's description. |
The person identifier value Note: The system
supports encryption for Person Identifier. If your implementation
has configured the system to encrypt Person Identifier, the data will
be displayed with a masked value; such as, *******.Refer to Encrypting Sensitive Data for more information.
Person - Main |
Email Address |
The person's email address |
Person - Miscellaneous |
Service Provider. |
The service provider's name and a description of the service provider's billing relationship as of the effective date. |
SA Relationship - Main |
This zone does not support User Interface Masking. If your implementation masks any of the information that appears on this zone, you must disable it and implement a zone that will mask your data appropriately. The demonstration system provides a sample zone that your implementation can import and then customize if necessary; this zone's code is CI_CIMAP. To disable the base package zone simply deny access to its associated application service. You should only grant access to your new Customer Information zone.
