Simple Summary
Simple Summary calculation rules create a "subtotal" on the bill by summarizing bill lines produced by other calculation rules in the same calculation group.
- Rule Name: Simple Summary
- Base Package Calculation Rule Business Object: C1-SimpleSummary
- Apply Calculation Rule Algorithm Type / Algorithm: C1-SIMP-SUMM
Rule Parameters:
- Referenced Calculation Rules: Defines the calculation rules that should be included in the summary. Note that any calculation rules listed here must belong to the same calculation group as the Summary rule.
Example: This calculation rule creates a summary of
TOU-based charges (based on rules within the same calculation group
as this rule).
Calculation Group: Commercial TOU Electric Charges
Calculation Rule: KWHTOT
Sequence: 40
Description: Consumption Subtotal
Description On Bill: Consumption Subtotal
Print: Yes
Print if Zero: No
Rounding Type: Nearest
Precision: 0.01
FCPO: No
- Off Peak - kWh
- On Peak - kWh
- Shoulder Peak - kWh
Cross Reference:
- Member Category (Category Type / Value): Taxable / State Tax
