Stepped Service Quantity
Stepped Service Quantity calculation rules create bill lines that levy charges based on some type of consumption when different prices are applied to different ranges of consumption (for example, the first 50 kWh are $0.43 per kWh, anything in excess of 50 kWh is charged at $0.71 per kWh)
- Rule Name: Stepped Service Quantity
- Base Package Calculation Rule Business Object: C1-SteppedSQ
- Apply Calculation Rule Algorithm Type / Algorithm: C1-STPD-SQ
Rule Parameters:
Calculation Details: Details regarding how the calculation
rule performs its calculations:
- Unit of Measure: The UOM used as the service quantity that the price is applied to.
- Time of Use: The TOU used as the service quantity that the price is applied to.
- Service Quantity Identifier: The SQI used as the service quantity that the price is applied to.
- Error If No Value: A flag that indicates (Yes or No) if a bill error should be generated if the UOM/TOU/SQI specified on the rule was not supplied at billing time.
- Measures Peak: Indicates (Yes or No) if the UOM/TOU/SQI specified for the rule is used to measure peak (demand) values.
- GL Statistical Qty: A flag that specifies (Yes or No) if GL journal lines generated for this calculation rule should also contain the service quantity amount as a statistical quantity. You would use this option if you keep track of both dollar amounts and consumption units in your general ledger.
Create Step Summary: Stepped service quantity
calculation rules may be configured with either a single step or multiple
steps. The Create Step Summary flag is used to produce a summary bill
segment calculation line if the calculation rule has multiple steps.
Valid options include:
- Summarize Step Lines, Print: Creates a stepped charge summary bill line that will appear on the customer's bill.
- Summarize Step Lines, Do Not Print: Creates a stepped charge summary bill line that will be shown on Bill Segment - Calculation Details, but not appear on the customer's bill.
Step Calculation Details:
- Seasonal: See Common Parameters.
- Step Multiplier Algorithm: Specifies the algorithm that will be used calculate the step boundaries. Used only if step boundaries are dynamic and are calculated based on something that's only known at billing time.
Values: Defines the values associated with each
of the ranges (steps) of consumption used by the rule. For example,
if the charge is applicable to the first 300 kilowatt-hours, you would
enter Low Value 0 and High Value 300. When multiple tiers exist, the
high value of the first tier is the low value of the second tier (and
so on). To extend our example, the second tier would have a low value
of 300; the high value may be left blank (the system assumes a blank
high value means "to infinity").
Low Value: Defines the low value for the consumption
range. This field supports values of up to 14 digits and 4 decimal
places (e.g. a maximum value of 99,999,999,999,999.9999).
You can indicate that the low value of a bill line should be substituted into the bill line's description by using the %L substitution variable in the calculation rule's Description On Bill field.
High Value: Defines the high value for the consumption
You can indicate that the high value of a bill line should be substituted into the bill line's description by using the %H substitution variable in the calculation rule's Description On Bill field.
- Value Type: Defines the type of price to be applied to the consumption range in the rule's calculations. Valid options include Charge, or Unit Rate.
- Value Source: Defines the source of the price to be applied to the consumption range in the rule's calculations. Depending on the source selected, this will be a Bill Factor, Value, or Algorithm.
- Value/Bill Factor/Algorithm: Specifies the Bill Factor, Value, or Algorithm used when calculating charges for the consumption range.
Example: This calculation rule calculates charges
for electric service based on stepped charges for kWh consumption
during the Fall
Calculation Group: Electric Residential - Stepped
Calculation Rule: KWHSTFL
Sequence: 10
Description: Fall kWh Stepped Charges
Description On Bill: Usage %Q kWh at %I per kWh %F
Print: Yes
Print if Zero: No
Rounding Type: Nearest
Precision: 0.01000
FCPO: No
Override Proration: No
- Unit of Measure: Kilowatt hour
- Error If No Value: No
- Measures Peak: No
- GL Statistical Qty: Yes
Create Step Summary: Create Summary, Do Not Print
- Seasonal: Yes
- Seasonal Prorate Method: Accounting Date
- Season Start: 09-01
- Season End: 11-30
Value 1:
- Low Value: 0
- High Value: 300
- Value Type: Unit Rate
- Value Source: Value
- Value / Bill Factor / Algorithm: 0.0485
Value 2:
- Low Value: 300
- High Value: [blank]
Value / Bill Factor / Algorithm: 0.0564
GL Distribution:
- Distribution Source Code: Specific Distribution Code
Distribution Code: Revenue - Electric - Residential
Cross Reference:
- Member Category (Category Type / Value): Revenue / Consumption Charge
