Activating a Scheduler Batch Stream Definition
Once the Scheduler Batch Stream Definition is ready, it can be activated in the SaaS batch Scheduler to run at periodic intervals by transitioning the Scheduler Batch Stream Definition to Active state. An activated Scheduler Batch Stream Definition is called a Scheduler Batch Stream. A Scheduler Batch Stream runs based on the schedule defined on it.
![Transitioning the Scheduler Batch Stream Definition to Active state activates it in the SaaS batch Scheduler to run at periodic intervals.](../images/K1_CSF_BO_Scheduler_Batch_Stream_Definition_Lifecycle.jpg)
By default, every batch job in a Scheduler Batch Stream Definition is internally setup to run in such a way that if that batch job fails the Scheduler Batch Stream run stops execution. User then has an option to fix the issue and re-start the stream.
