Cut Process Information Is Overridable
"Cut process info" is the concatenated string of information that summarizes a cut process throughout the system. The base-package logic constructs this string by concatenating the following information:
  • Its cut process template's description
  • Its status
  • For active processes, the number of days since it was created. For inactive processes, the number of days since it was inactivated.
  • For active processes, the unpaid amount of the objects being collected on the cut process's overdue process
If you'd prefer a different info string, you can develop a new algorithm and plug-it in on your cut process templates. This design allows some / all cut process templates to have an override info string.
