Cut Processes Exist Under An Overdue Process
It's important to note that a cut process exists in respect of an overdue process. In other words, you can't create a cut process without referencing a parent overdue process. There are two reasons why:
  • A cut process's overdue process defines the objects in arrears. It is these objects that are monitored to determine if the cut process (and overdue process) can be cancelled.
  • The log associated with a cut process's overdue process contains the history of the cut process(es) and their events; there is no log specific to a cut process.
