Calculation / Audit Usage Details
We use the term "calculation / audit usage" to describe service quantities retrieved from the bill segment's usage request. An example of when calculation / audit usage may be required:
  • When usage requests are sent during billing to Oracle Utilities Meter Data Management, usage details may be returned to Oracle Utilities Customer Care and Billing as part of the usage request response. Oracle Utilities Meter Data Management might return both usage details and meter reads to print on the bill.
Usage service quantities are also stored in a bill segment's read details (the name of the table is CI_​BSEG_​READ ). The following points describe the main features of calculation / audit usage:
  • Calculation / audit usage may or may not reference a service point.
  • Calculation / audit usage does not reference the prime key of a real read.
  • Calculation / audit usage has a usage flag with a value of Service Quantity.
  • Calculation / audit usage does not require a UOM code. If a UOM is not supplied, an SQI must be supplied.
If you encounter other scenarios during your implementation that necessitate calculation / audit usage, you can develop bill segment type and calculation rule algorithms to add additional calculation / audit usage to a bill segment's read details.
Calculation / audit usage details are shown in a separate section on Bill Segment - SQ Details.
