Proposal SAs Contain Billing Scenarios And Template Consumption
In addition to the pricing
terms and the legal terms and conditions, a proposal SA also contains billing scenarios. A billing scenario defines:
- The number of simulated bill segments that will be generated when a quote detail is produced for the proposal SA.
 - The bill period of each simulated bill segment.
 - The amount of consumption to be priced under each simulated bill segment. Note this statement is only true for non-interval consumption. Note: Proposal SAs that use interval consumption are not supported in C2M. Load curves and TOU mapping are handled in Oracle Utilities Meter Data Management.
A proposal SA's billing scenarios can be created
as follows:
- A plug-in spot exists on SA type called Proposal SA Creation. Algorithms plugged into this spot can setup billing scenarios. Refer to Enabling The Automatic Generation Of Billing Scenarios for more information about how to do this.
 - A user can add / change / delete billing scenarios on a proposal SA using Service Agreement - Billing Scenario.
