Maintaining Settlement Billed Usage
You use the portal Settlement Billed Usage portal to view and maintain settlement billed usage.
Refer to About Settlement Billed Usage for additional functional information.
You can access the portal from the Main > Settlement > Settlement Billed Usage. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Settlement Billed Usage: This zone displays basic information about the settlement billed usage, including billed usage periods.
