Email Notification
If you wish the system to inform you when the background process completes, you may supply your email address. The email you receive will contain details related to the batch job's output; similar to the job results you would see from your batch scheduler.
The email includes information from the product installation to help users that may be working in and submitting background processes in more than one environment.
  • It includes the product name and product version for the product in the installed products list that is marked as the one to display.
  • If a domain name message is configured in the installation messages, this information is also included.
This assumes that during the installation process, your system administrator configured the system to enable email notification. Your administrator may also override the amount of detail included in the email notification.
A batch control parameter may be used to indicate if the email should only be sent in the case of an error or success or both. Refer to Parameters Supplied to Background Processes for more information.
