Jobs Submitted in the Background
When you save a record on the batch job submission page, the batch job does not get submitted automatically. Rather, it saves a record in the batch job table. A special background process will periodically check this table for pending records and will execute the batch job. This background process will update the status of the batch job submission record so that a user can determine when their job is complete.
At installation time, your system administrator will set up
this special background process to periodically check for pending
records in the batch job submission table. Your administrator will
define how often the system will look for pending records in this
table.
It should be noted that this special background process only submits one pending batch job submission record at a time. It submits a job and waits for it to end before submitting the next pending job.
If you request a batch job to be run multi-threaded, the special background process will
submit the job as requested. It will wait for all threads to complete before marking the batch
job submission record as ended. Refer to  Running
Multi-threaded Processes for more information.
