Analytics Configuration
This portal provides a bird's eye view of the configuration information for Oracle Utilities Analytics. It provides links and guidelines for the areas that need configuration to successfully run the extract transfer and load processes from Oracle Utilities Analytics.
You can access the portal from the Admin, select A, and then select Asset Analytics Configuration.
The following zones may appear as part of the portal's Main tab page
  • Analytics Extract Parameters: This zone displays the extract data to set up.
  • Bucket Configuration List: This zone displays bucket configuration to set up.
The following zones may appear as part of the portal's ODM tab page
  • BI-Oriented Extendable Lookup: This zone displays extendable lookups to set up.
  • BI-Oriented Master Configuration: This zone displays master configuration to set up.
  • Bucket Configuration Tree: This zone displays tree view of analytics data.
