Defining Manual Work Activity Completion Options
This topic outlines the configuration needed to support manual work order activity completion processes.
Create Action Method
You must configure an Action Method to manually complete work activities using the Process Flow portal.
Use the following procedure to create an action method used with manual work order activity completion processing.
Select Admin, select System, select Action Method, then select Add.
Select "Work Activity Completion Action Method" from the Action Method Business Object drop-down list on the Select Business Object screen and click OK.
- Enter the following on the Action Method screen:
Action Method: A code for your action method
Action Method Role: Work Activity Completion
Description: A description of your request type
Process Flow Type: Work Activity Completion Process
Click Save.
See Defining Action Methods for more information about creating Action Method records.
