Configuring Message Senders
This section provides guidelines for configuring the components needed to support outbound messages to the GIS system.
Note: For WACS (OCI Cloud) environment, Http/https in the Message Sender URL should be replaced with the substitution variable @EXT_​PUB@. And the ArcGIS Server services should be served over port 443 since only port 443 will be accepted in OCI environment.
Define a message sender for each of the outbound message types associated with the GIS Integration web service category using following guidelines.
Message Sender for Work Location
Field / Context Value
Invocation Type Real-time
Message Class SOAP: RHTTPSNDR (Send post messages via HTTP real-time)REST: RTJSONSNDR (Sender for real-time HTTP/JSON messages)
MSG Encoding UTF-8 message encoding
HTTP Method POST
Active Yes
HTTP URL 1 The URL of the corresponding service to be provided by GIS team.
WAM REST Ex: https://xxxxxxxxxxxxx:6443/arcgis/rest/services/WAM/WorkLocations/FeatureServer/0/${pathParms}
WACS REST Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/rest/services/WAM/WorkLocations/FeatureServer/0/${pathParms}
WAM SOAP Ex: https://xxxxxxxxxxxxx:6443/arcgis/services/WAM/WorkLocations/MapServer/FeatureServer
WACS SOAP Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/services/WAM/WorkLocations/MapServer/FeatureServer
HTTP Header REST: Content-Type:application/x-www-form-urlencoded
HTTP Header REST: Accept:application/json
HTTP Form Data REST: adds=@XMLMSG@
Message Sender for Asset Outbound Sync
Field/Context Value
Message Class SOAP : RHTTPSNDR (Send post messages via HTTP real-time) REST: RTJSONSNDR (Sender for real-time HTTP/JSON messages)
HTTP Method POST
Active Yes
HTTP URL 1
WAM REST Ex: https://xxxxxxxxxxxxx:6443/arcgis/rest/services/WAM/DistributionNetwork/FeatureServer/${pathParms}
WACS REST Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/rest/services/WAM/DistributionNetwork/FeatureServer/${pathParms}
WAM SOAP Ex: https://xxxxxxxxxxxxx:6443/arcgis/services/WAM/DistributionNetwork/MapServer/FeatureServer
WACS SOAP Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/services/WAM/DistributionNetwork/MapServer/FeatureServer
HTTP Form Data REST: Edits=@XMLMSG@
Message Sender for Asset Inbound Sync
Note: This communication supports REST protocol only.
Message Class RTJSONSNDR (Sender for real-time HTTP/JSON messages)
HTTP Method POST
Active Yes
HTTP URL 1
WAM REST Ex: https://xxxxxxxxxxxxx:6443/arcgis/rest/services/WAM/ExtractDeltaChanges/GPServer/${pathParms}
WACS REST Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/rest/services/WAM/ExtractDeltaChanges/GPServer/${pathParms}
Message Sender for Token Generation
Note: This configuration is required only if the underlying map service published in ArcGIS Server are secured.This communication supports REST protocol only.
HTTP Method POST
Active Yes
HTTP URL 1
WAM REST Ex: https://xxxxxxxxxxxxx:6443/arcgis/rest/services/WAM/GenerateToken/GPServer/${pathParms}
WACS REST Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/rest/services/WAM/GenerateToken/GPServer/${pathParms}
