Maintaining Metered Service
The Metered Service portal is used to display and maintain metered service records.
Refer to About Metered Service for more information.
You can access the portal from Menu, select Digital Asset Management, then select Metered Service. You are brought to a query portal with options for searching for a specific record. Once a metered service records has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Metered Service: This zone displays general information about the metered service records.
Program Subscriptions: This zone displays a list of "child" program subscriptions associated with the metered service record.
Attribute Values: This zone displays a list of attribute values whose characteristic type have Program Subscription as characteristic entities and are defined as valid Program Subscription characteristic types on the Program Subscription Type.
Settlement Group Program Subscriptions: This zone lists program subscriptions that have the metered service defined as their Settlement Group.
