Oracle Utilities Work and Asset Management Installation Guide
Overview
Product Overview
Installation Overview
Installation Types
Initial Installation
Upgrade Installation
Demo Installation
Package Contents
Documentation
Installation Packages
Readiness Checklist
Supported Platforms and Hardware Requirements
Operating Systems and Application Servers
Application Server Memory Requirements
ESRI Integration Supported Versions
ArcGIS Server Version Compatibility
ArcGIS Desktop Version Compatibility
Support for Software Patches and Upgrades
Planning the Installation
Installation Considerations
WebLogic Native Installation
Application Server Clustering
Directory Names
Prerequisite Software List
Prerequisite Software for Database Server
Prerequisite Software for Application Server
Web Browser Requirements
Installing Prerequisite Software
Oracle Linux Application Server
Oracle Solaris Application Server
Windows Server 2012 R2 Application Server
Additional Prerequisite Software Information
Setting Up and Using the Additional JAR Directory
Special Note to Upgrade from a WebLogic 12.1.3.x Environment
Installing Oracle Utilities Work and Asset Management - Initial Installation
Initial Installation Procedure
Installing the Database Component
Installing the Application Components
Post Installation Verifications
Installing Oracle Utilities Work and Asset Management - Demo Installation
Demo Installation Procedure
Database Component Installation
Application Component Installation
Upgrading Oracle Utilities Work and Asset Management
Upgrade Paths
Before You Upgrade
Upgrade Procedure
Database Component Upgrade
Application Component Upgrade
Post Upgrade Verifications
Installing Service Packs and Patches
Additional Tasks
Importing Self-Signed Certificates
Customizing Configuration Files
Customizing Centralized Properties
Integrating Existing Customer Modifications
Building Javadocs Indexes
Configuring the Environment for Batch Processing
Customizing the Logo
Creating WebLogic Domain
Deploying Inbound WebServices (IWS)
Domain Templates
Database Patching
Installing Optional Products
Oracle Analytics Publisher
Supported Analytics Publisher Versions
About Oracle Analytics Publisher Enterprise
Configuring the System to Enable Reports
Sample Reports Supplied with the Product
ESRI ArcGIS Server (WAM Only)
Supported ESRI ArcGIS Server Versions
Installing and Configuring the ESRI ArcGIS Desktop
Installing and Configuring the ESRI ArcGIS Server
Configuring the Enterprise Geodatabase
Importing Data to Geodatabase
Publishing Data as Services in the ArcGIS Server
Creating Web Maps Using ArcGIS Online
Installing the ArcGIS Web Adaptor
Installing and Configuring the ArcGIS Portal
Creating Web Maps Using the ArcGIS Portal
Configuring Inbound Sync (GIS)
Changes to ENVIRON.INI
Importing Certificates into ouaf truststore
Installation Menu Functionality
Installation Menu Functionality Details
Installation and Configuration Worksheets
Menu Block 1: Environment ID, Roles, Third Party Software Configuration
Menu Block 2: Keystore Options
Menu Block 50: Environment Installation Options
Menu Block 1: Environment Description
Menu Block 2: [WebLogic] Business Application Server Configuration
Menu Block 3: [WebLogic] Web Application Server Configuration
Menu Block 4 - Database Configuration
Menu Block 5 - General Configuration Options
Menu Block 7 - OUAF TrustStore Options
Menu Block 8 - OSB Configuration
Menu Block 9 - SOA Configuration
Menu Block 10 - SOA Configuration Plan (MDM)
Menu Block 11 - Configuration for DataRaker Integration
Menu Block 16 - SOA Configuration Plan (LG)
Menu Block 17 - SOA Configuration Plan (NES)
Menu Block 18 - SOA Configuration Plan (Sensus)
Menu Block 19 - SOA Configuration Plan (SSN)
Menu Block 20 - SSN JMS Source Destination Bridge Configuration
Menu Block 21 - DG Reference Implementation SOA Configuration
Menu Block 22 - SOA Configuration Plan (Itron Openway)
Advanced Menu Options
Common Maintenance Activities
Oracle Utilities Work and Asset Management 2.4.0.1.1 Installation Guide
