Defining Measurement Identifiers
The Measurement Identifier portal is used to display and maintain measurement identifiers.
You can access the portal from Admin, select M, then select Measurement Identifier.
- Measurement Identifier List: This zone lists all measurement identifier records. Broadcast a record to display the details of the selected record.
- Measurement Identifier: This zone provides information about the selected measurement identifier.
