Checking In an Object
You must check in a revision controlled object in order to create a new version of it. Checking in an object also allows others to check it out.
- Select a link in the Checked Out sidebar zone to go to the object that you want to check in.
- Select Check In in the Revision Control sidebar zone.
Provide details about the version:
- In the External References field state the bug number, enhancement number, or a reason for the revision.
- In the Detailed Description field provide additional details regarding the revision.
- In the Keep Checked Out box specify if you want to keep the object checked out. If you keep the object checked out then your revision is a new version that you can restore later.
- In the Add To Bundle box specify if the object belongs to a bundle.
- Select OK to check in the object.
