Checking Out an Object
You must check out a revision controlled object in order to change it.
An object must have revision control turned on before you can check it out.
When
you first create or update an object a dialog box informs you that
the object is under revision control. You can select OK to check out the object and save your changes, or Cancel to stop the update.
- Go to the object that you want to work on.
- Select Check Out in the Revision Control sidebar zone.
