3.2.1 First Level Issues
Learn about the issues you may encounter when using during the basic investigation and how to work around them.
Topics:
Calls are not sent properly
Null pointer or branch common exception error
If there is a null pointer exception or branch common exception error, go to the process log table and exception log table, and select the following queries to verify the results.
Table 3-3 Queries to Verify Results
Query | Reference for Sample Log |
Process log contains request payload, which will help you to hit service through postman and for getting the response.Exact error through exception log
-Dplato.service.logging.path
variable in the
setEnv.sh
. For example, the path is
/scratch/Weblogic/serverlogs
Logs are not generated
The call is failing in the adapter
If any call is failing in call to Product Processor Gateway, open SRV_TB_AD_CENTRAL_TXN_LOG in Adaptor for getting Gateway response (SUCCESS or FAILED). Select the following query to verify results.
select * from SRV_TB_AD_CENTRAL_TXN_LOG order by REQ_DATE desc
404 Error
The possible causes for 404 error are as follows:
Check service is not running on Eureka
Check service is not deployed in WebLogic
500 Internal Error
The possible causes for 500 internal errors are as follows:
Issues with entries of Oracle Banking Microservices Architecture
Issues with Eureka
Issues with any piece of code
The server-side debugging is needed for the above-mentioned issues if it is not captured in logs.
Parent topic: High-Level Flow for Cash Deposit
