3.5.3 Setting Preferences for Participant Products
Preferences are those options you can use to specify attributes for a product.
These attributes are picked up and applied automatically to any contracts involving the
product.
For instance, for participant contracts using a participant facility product, you can define whether collection from the participants towards a drawdown must be initiated automatically; or whether the amount repaid by the borrower must be disbursed automatically to participants.
Specify the User ID and Password, and login to Homepage.
From the Homepage, navigate to Participant Product Definition screen.
Parent topic: Creating Participant Products
