3.6.1.1 Multi Switch Transaction
This topic provides information on Multi Switch Transaction.
Whenever a multi switch transaction is captured, the system will check the unit balance including unallocated units from any other outflow transaction of the same fund. If the unit balance thus calculated is less than the transaction value, the transaction generation will fail for Insufficient Unit Balance. For unallotted unit based or percentage based transactions, the system will identify the unallocated units from the transaction details.
For Amount based transaction, the system will compute the units balance as follows:
Unallotted units= Amount/ Latest Available NAV * (1 - Fluctuation %)
Note: Fluctuation % is a system level param value that can be maintained in Parameter Maintenance Screen (UTDPARAM) considering the maximum load and maximum fluctuation in price that can happen. PARAM Code to be maintained is FLUCTUATIONPERCENT.
Example
Table 3-24 Opening Balance
| Opening Balance | 120 |
| Buffer % | 5% |
| NAV | 11.23778 |
Table 3-25 TX N Details
| TXN | Txn Mode | Txn Value | Units redeemed | Settlement Amount | Outstanding | Txn Status | Remarks |
| RED1 | Units | 75 | 75 | 842.8335 | 45 | Success | No un-allotted Transactions during RED1 capture hence available units will be 120 |
| RED2 | Units | 50 | NA | NA | NA | Failed | Un-allotted units - 75 pending, hence system will consider the available units as 45 (120-75) |
| RED3 | Amount | 100 | 9.3669 | 105.2632 | 35.6331 | Success | System will use buffer % to arrive at units for amount based outflow transactions |
The system will run Multi Switch batch to generate pseudo switch in-leg. The system will split the pseudo out-leg and link to each pseudo in-leg (For instance, multiple switch out from 1 fund to 3 funds. There should be 3 out-leg link to 3 in-leg).If there is residual balance of units, it should be generated at the point of the allotment of pseudo switch out-leg.
Pseudo switch-in generation will be part of BOD sequence. The same can be scheduled as part of Mini-EOD, based on business requirement.
Parent topic: Process FCIS Bulk Transaction Detail
