3.6.1.2 Multi Transaction Capture Flow
This topic provides the information about the multi transaction capture flow details in the Transaction screen.
PS Out-leg Capture
In the header section the system will capture PS-Out leg details:
Table 3-26 PS Out-leg Capture
| Field | Description |
| UH ID | Investor ID |
| Fund ID | Switch-out fund ID |
| Net/Gross | Gross/Net |
| Transaction mode | Out leg mode |
| Multi switch out value | Switch-out value |
| Transaction Currency | Should be switch-out fund base currency |
PS In-leg Capture
The system captures PS In-leg details as part of the multi record on click of add rows icon.
Table 3-27 PS In-leg Capture
| Transaction Date | Defaulted from header |
| UH ID | Defaulted from header |
| Fund ID | Defaulted from header |
| Transaction Type | Should be switch |
| Transaction Sub Type | Should be Pseudo switch |
| Transaction Currency | Transaction currency |
| Transaction Mode | Only for Amount/Units |
| Transaction Value | Value to be switched |
| Gross/Net | Gross/Net |
| To Fund ID | Switch-in fund ID |
On saving, the system generates multi switch wrapper reference number. the reference number will be same as wrapper reference number.
Transaction number will be showing as key string till authorization.On authorization, the system will update the transaction reference number generated as key string to the actual switch out transaction number. The reference number will be same as wrapper reference number.
Error and overrides will be logged for the PS out transactions.Parent topic: Process FCIS Bulk Transaction Detail
