5.11.2.13 Executing LEDGER_STAT Load Procedure for MULTI CURRENCIES
The data for the Ledger can have more than one currency at a time that is multi currencies input.
To execute multi currencies, you need to enable the flag using the following statement:
update fsi_db_info f1 set f1.multi_currency_enabled_flg =1;
commit;
FTP supports the following two scenarios for Ledger Migration:- If multi-currency is not used:
FSI_DB_INFO
Multi_currency_enabled_flg = 0
Currency_type_enabled_flg = 0
Functional_currency_cd = same as iso_currency_cd in ledger and instrument data
Ledger Data (FE 100 and FE 140) must exist in LS and must only be in Functional currency (iso_currency_cd = functional currency and currency_type_cd = 2)
- If multi-currency is used:
FSI_DB_INFO
Multi_currency_enabled_flg = 1
Currency_type_enabled_flg = 1
Instrument Data can be in multiple currencies Ledger Data (FE 100 and FE 140) must exist in LS and must only be in Functional currency (iso_currency_cd = functional currency and currency_type_cd = 2). Exchange rate data should be present in Exchange Rate Direct Access table for converting entered currency to functional currency.
