9.5.1 Create and Execute a Custom Run Pipeline for Balance Computation Management Ledger Process
Create a custom Run pipeline for Balance Computation Management Ledger Process to compute the Daily Balances and Average Balances. Follow these steps:
  • Create a Run Pipeline
  • Create a Process Flow for a Run Pipeline
  • Select the Run Parameters and Execute the Run
  • Verify the Run Execution
The visual representation of the preceding steps is depicted in the following illustration. This is also an illustration of creating and executing a Run pipeline (process) using PMF in OFSBCE, in general.
Figure 9-44 Create and Execute a Custom Run Pipeline
For information about designing a Business Pipeline, see the Orchestration of a Business Pipeline section in the Oracle Financial Services Analytical Applications Infrastructure Process Modelling Framework Orchestration Guide Release 8.1.1.0.0.
Use a Business Pipeline to design a Business Process, which consists of a sequence of internal or external tasks through well-defined interfaces. Using the designer, you can design the entire business flows consisting of various types of tasks or another business pipeline.
To use a standard out of the box Run pipeline for Balance Computation Management Ledger Process, see the Balance Computation Management Ledger process section in the Use Standard OFSBCE Run Pipelines section.
