4.2.1 Using Views
The following are the salient features of Views search.
- Views represent pre-populated search queries.
- Views allow a single-click option for returning a filtered case list based upon the view's preset search criteria.
- Search fields are displayed based on the type of Views you select.
- You can create and manage personal saved views.
To search for cases using the Views search, follow these steps:
- Navigate to the Case Search and List page.
- Select a view type from the Views drop-down list.
Figure 4-2 Case Search and List screen
The relevant cases are displayed in the Case List pane.
For more information on the Views search, see the following table:
Table 4-1 Case Views and Filter
| View Name | View Filter |
| My New Cases | Displays cases in New Status for which the owner is the logged-in user or the poolto which user belongs. |
| Cases Assigned to Me | Displays cases for which the assignee is the logged-in user or the pool to which user belongs in any status except Closed. |
| My Open Cases | Displays cases for which the owner is the logged-in user or the pool to which user belongs, in any status except Closed. |
| My Overdue Cases | Displays cases for which the owner is the logged-in user or the pool to which user belongs and the due date is equal to or less than current date. |
Views also display your personal saved views. These search views are created using the Save View option. For more information, see Creating a Search View.Creating a Search View
The Save View option allows you to create and manage personal search criteria for your future uses. You can also make Search View as a default search criterion. The newly created search views are listed in the Views Search drop-down list and User Preference page. These search views are available only to the user who creates it.
To create search views, follow these steps:
- Enter your search criteria in the Advanced Search fields
and click Save As View.
Figure 4-3 Advanced Search
The Save View window is displayed.
Date filters or ID filters are not permitted for saving a View. - Enter a View Name for the personal search view.
- Optional: Select Set as Default Search to make this Search View as default search criteria for all your future uses.
- A confirmation message displays and a newly created save view displays in the Views drop- down list. This save view is also displayed in the User Preference page. For more information, see Setting User Preferences.
