11.5.8 Publish Model Draft
After creating the Draft Models, publish the Notebooks, which have the Model script.
You can publish a model draft to Data Studio from the Pipelines flow. Publishing can be initiated from either of the following locations:
  • From the pipeline or draft screen.
  • From the Model Summary screen by using the Actions icon (three dots)
  • From Model Summary (Actions menu)
To publish from the Model Summary screen:
  1. Navigate to the Model Summary screen.
  2. Click the Actions icon (three dots).
  3. Select Publish Model Draft.
    (Limitation): When you are publishing from the Model Summary screen, the link information (for example, training and scoring links) is not retained because the Publish action is executed from the summarized content (selected paragraphs). As a result, the trainingor scoring links are defaulted to default in the published output. To preserve the configured links, publish the model draft from the pipeline or draft screen.
To publish:
  1. Create a Draft Model. See the Create Draft Models section for more information.
  2. Click next to corresponding Draft Model and select Publish Data Studio option.
    The Publish Model window is displayed.
    Figure 11-118 Publish Model
    This image displays the Publish Model.
  3. Enter the details as shown in the following table.
    Table 11-29 Field and its description for the Publish popup window
    Field or Icon Description
    Model Name The field displays the name of the Model. Modify the name if required.
    Model Description The field displays the description for the Model. Enter or modify the description if required.
    Technique Enter the registered technique to use.
    Run Version Select a run version.
    Script
    The table displays the Paragraphs created in the Training Model. Select the Paragraphs that you want to use to create the Scoring Model.
    Track Output - Select this to track the output of the paragraph.
  4. Click Publish.
