Accessing Scheduler Optional Parameters Inside Studio Model Paragraphs
The Scheduler Service automates the running of models in the application. The Scheduler Service contains a graphical user interface and a single control point for defining and monitoring background executions.
For more details on the Scheduler Service, see Scheduler Service section.
To access the optional parameters passed from the Scheduler during execution of any models, run the following script:
To print
print('BATCHRUNID value is : ${$BATCHRUNID$}')
print('TASKID value is : ${$TASKID$}')
print('FICMISDATE value is : ${$FICMISDATE$}')
To access the optional parameters passed during execution of any models, run the following scripts:
%python
print('threshold value is : ${threshold}')
Threshold is the optional parameter passed during the model execution.From scheduler task/edit dynamic parameters, the aprameter set to a model can be passed in optional parameter textbox as parameterSets=Set1 where parameterSets is the key for paramter sets and Set1 is the actual set value.
From EICS it is as below:
./EICSchedulerService.sh -o 1 -u mmgadmin -w CS -c ofsauser -s secret -x 232 -b BatchModel -t rest -v '{"batchParams":{"$FICMISDATE$":"2021-11-30","$BATCHRUNID$":"BATCHRUNID"},"taskRuntimeParams":{"Task1":{"optionalparams":"parameterSets=Set1"},"Task2":{"optionalparams":"parameterSets=Set2"}}
